Contributor dose not have Post Settings when creating post / article
I would like to give Contributor options to use Post settings for each post / article he creates, is there a way to do that? Author have Post Settings enabled but he can also publish and i dont wan’t that for Contributor.
Best regards
Sorry but our theme does not have a role manager to grant or remove access to theme features from a particular user role. You will need to use a plugin in order to change the default user role and capabilities for your users.
