“Convert to blocks”: Problems with WordPress 6.7
since WordPress 6.7 nothing happens if I click on “Convert to blocks” of a classic block in the Gutenberg editor.
In the console of chrome there is a message:
Uncaught SyntaxError: Identifier '__' has already been declared (at td_js_for_guten_blocks_editor.min.js?ver=def8edc4e13d95bdf49953a9dce2f608:1:1)
(anonymous) @ td_js_for_guten_blocks_editor.min.js?ver=def8edc4e13d95bdf49953a9dce2f608:1
Is this the reason why nothing happens and classic code gets not converted into blocks? How can I fix this?
Please let me know what version of the theme you have. I did a test, and for me, it works.
Thank you for your answer. Knowing that it worked for you, I did some research and found out, it’s a conflict with the plugin Advanced Editor Tools.
Resolved.
I’m glad that you found the plugin that caused the issue.
Have a great day!
