Corrupted view Mobile Pages, Posts work ok
Hopefully you can provide some direction. Pages do not appear to be rendering in Mobile view. Looking for blanket suggestions for all “pages”.
Sample of mobile view in iOS
Page url: https://www.makingyouthink.ca/recommended-book-reads
I saw that you have the mobile theme +amp, so those are two options: use the amp only on the posts, without pages, or disable the amp only on that page; for this, you need to disable the mobile theme plugin, go to that page and use the amp option to disable it from the page after that enable the mobile theme plugin after doing this the mobile theme and amp versions will be disabled on that page.
