Cover article image post style problems
Hello! I have problems in the post templates cover images.
I have only 3 post template that works, showing correctly the cover images: Style 6, Style 7, style 8 do work.
All other post templates do not work.
For example this is a post style 4. The image is not displayed!
http://www.giochi-da-tavolo.it/terraforming-mars/
What do you think is the problem? Do you think is some theme panel option?
The featured image is correctly set in the edit post page.
The article cover image size is: 600 × 458 px; 51 kb
Thanks a lot!
Replied in your other topic.
