Cover / front-images not loading on blocks
If you go to
https://www.cavemantraining.com/a-caveman-in-nepal/
and scroll to the bottom where the two blocks are: block 11 and big grid full 9
you’ll see the cover images are not displayed. But when including these blocks on the homepage they show fine.
