I have installed the Prebuild Website News Magazine Pro, and some single Post templates in Cloud Templates.
However, when I select the Single Post Template 11 or 16, the cover image is not displayed at full width.
See this screenshot:
https://www.uberti.eu/images/ESEMPI/template-11-screenshot-1.jpg
Questions:
1) How do I display the cover images of Single Post Template 11 and 16 at full width?
2) How do I remove the gray geometric pattern on the sides of the post?
Hello @zagasir!
If you mean this style: https://prnt.sc/tUzN5XsrVKoc, then this is a default one and can’t be modified in the TagDiv Composer. So, you can’t edit the gray edges.
Which is the 16th template? If it is a cloud one and can be edited with the TagDiv Composer, then we have some settings for the rows and different stretch sizes: https://www.screencast.com/t/bsbB5P97A -> https://prnt.sc/icoqdTR9_DMS
Bettina,
I did not ask how to modify a style.
What I asked was why the Single Post Templates 11 and 16
https://www.uberti.eu/images/ESEMPI/post-template-11.jpg
Instead of appearing as they should by default with the cover image in full width,
https://cloud.tagdiv.com/#/single/single/Single/25
https://cloud.tagdiv.com/#/single/single/Single/93
they appear like this:
with the cover image NOT in full width
I haven’t changed any settings of the post templates: why doesn’t the cover image appear in full width?
Another question: how do I remove the background design on the right and left sides and make the background white?
https://www.uberti.eu/images/ESEMPI/remove-background.jpg
Hello @zagasir!
Remove the background image https://prnt.sc/Jj-tMDLZvjL0 from the theme panel and the template will be displayed in the full width as well.
