CPT posts load cloudtemplate but do not load the custom header
so we create a CPT with the plugin “PODS” and select in Cloudtemplates CPT and set it as global.
The post connects immediately to the created Cloudtemplate, but it ignores the connected header.
If i edit the Cloudtemplate in TagDiv it displays the right header – also in preview. But once I go into the posts, where it is used in the header is switched to the default global header again.
How can I change that and where could be a bug?
Hello @FBM!
Please make sure the header template is set as global.
Make a test and deactivate ALL plugins except tagDiv ones. If you are using a cache plugin, deactivate it and see if the problem goes away.
