CPU Problem
Hi there!!
I am experience some CPU problems (overload, pikes and failures) and also an excessive inbound process every time I tried to even add a new image to the gallery. I have been reading in the forum that there are many people with this short of problem BUT there is no solution for that behavior. I have checked all the plugins one by one and I can guess is the composer… Any idea how to solve it??
Mi hosting is a 1 core and 2gb and until a few days (when I tried to convert everything to newspaper 10) it worked fine. The website (https://howpple.com) is really fast but the CPU load got to 100% and doesn’t let me even to upload a single image.
I have deactivate all the plugins, clean the database and even try with a different theme which make my site and CPU works smooth, but everytime i use Newspaper the problems come back.
I need a solution because i cannot even post a single post 🙁
  • This reply was modified 6 years by espedfk2. Reason: add website link
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
Sorry to disturb you are using newspaper 10 without the standard plugin how did you get the LIST LAYOUT?
Hola, espedfk2, me encanta lo rĂĄpido que carga tu web. ÂżCĂłmo lo consigues con Newspaper? Por mĂĄs que lo intento los test de velocidad siempre son malĂ­simos…
Hola Leytol:
La verdad que he tardado hasta entender un poco el funcionamiento de Newspaper X. He tenido que rehacer todas las paginas con el nuevo sistema de Cloud Template y una vez hecho todo desactivando el Standard Plugin para aumentar la velocidad (compruébalo varias veces porque alguna sección da bastantes problemas), he eliminado plugins no necesarios e instalado unos nuevos como perfmatters que ayudan bastante. Si tienes dudas pregunta ;P
Hi there iamkingsleyf:
I redo the whole website using the Cloud templates and following the steps including in Newspaper X and after that I just deactivate the Standard plugin keeping all that was done before
