Hello everyone.
First, I apologize me if ever the answer is already on the forum , I have not yet found the solution aps .
So, I created a module using the model No. 77, it works and I applied to an archive page for a taxonomy.
I would like to show 3 items per row instead of two , I do not find where I can settle this . Are anyone have a solution or a link to a solution?
Thank you very much anyway, this forum is very informative .
You can change the columns number by changing this numbers: http://screencast.com/t/SsdHVMOh – http://screencast.com/t/iKqcxD3iY Note that this modification will affect all modules which use the columns layout. Also you can create a custom function only for that module, using the same implementation. Also you may need some style customizations such that the items to be displayed fine on three columns layout.
Note that this is a complex task which require good coding skills and if you’re not aware by the steps you need to take in this regard please consider hiring a freelancer from sites like http://studio.envato.com/ to do it for you.
