Can I create product category pages with cloud templates? I’ve tried, but instead of creating product category pages, it creates a single product archive. It seems to be interpreting the product archive as one category.
Here’s what I’m doing:
1. Open the default product category page (created by Woocommerce)
2. Click “Template” up top
3. Select and import a Cloud Template
4. My chosen Cloud Template appears. But it recognizes my entire product archive as the category, with 30+ pages listing all 400+ of my products.
I want to create a template for my product category pages (300 category pages). I would like each category page to display the header image for that category (which I assigned to that category in the categories tab in WordPress) and all products within that category.
Is this possible?
This topic was modified 3 years by
Miller-J.
Yes: https://prnt.sc/XKDOkL-TaH5Y
Make sure you set the cloud template global : https://prnt.sc/AQcymBHGgw-E, so the global template will be applied on all your categories.
I want to display a unique header image on each category page. If I add a header image to a category page and set the teamplate to global, it assigns the same header image to all category pages.
Is there an element that can pull the corresponding unique category image from Woocommerce? I can’t find such an option.
Yes. The element called “Woo Archive BG Image” it will take the image set it here: https://prnt.sc/PPbyuXbAw1Gp -> https://prnt.sc/Zu3tVWTEpoc4
Go to Products -> Categories, click view category and make sure you have a cloud template. Edit it with the TagDiv Composer -> https://prnt.sc/XsGNTvvN8BAZ
