I seen that ACF plugin isn’t on your list of tested plugins . . .however – for creating a custom post type layout – is there a way to add custom fields within the Newspaper theme? or approved/tested plugins that allow that option to happen?
Hi Chris Baird, indeed the ACF plugin isn’t on our list, but as I know this is working correctly with standard templates, as I know there are some problems on cloud, is harder to be use with cloud templates, but with standard templates will be no problem, if you want you can make some tests.
-> https://forum.tagdiv.com/topic/acf-into-cloud-template/
