Our SNAP Settings are set as follows:
Publish Immediately
Skip User Security Verification (Checked)
Yet these Settings will not stay in place, no matter how often we set them & click Update Settings. They hold for a few hours and when we return to Settings, they have automatically reverted to:
Use WP Cron to Schedule
Skip User Security Verification (UNChecked)
We’ve used your tool to test the Cron Job and it is fine. Cache has always been cleared, but the same problem returns.
From what I understand, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
Deactivating ALL plugins except tagDiv ones, caches, etc. did not resolve issue. Credentials have now been sent to you.
