Css Buffer problem
I just find a issue.
When custom fonts change, td_fonts_css_buffer (option) not updating. Can you fix it please!
Cheers,
You mean you set a custom font, change something on the Custom Typography section and then make another change on the custom fonts? please provide more details.
Thank you, Emil G.
Hello Emil,
Yes.
I changed font url, but it wasn’t affected. Then I check options in database and see that problem, td_fonts_css_buffer value didn’t update when changes save.
It was made this way to lower the size of the data delivered to the server on one save. Most servers come with default max_input_vars set to 1000 and in the past because of it we had users on which the Theme Panel didn’t save the data, to avoid this we had to break everything into sections.
We’ll look into it to see if there’s an option but we don’t want to get back to the old issue so i cannot promise anything yet.
Thank you, Emil G.
