CSS problems after importing Demo
I have some CSS style problems after installing Demo content.
Attached in the capture you can see what I’m talking about. Hope you can tell me how to fix this issue.
http://baztanet.com/wp-content/uploads/2017/04/Captura-de-pantalla-2017-04-25-a-las-13.10.35.jpg
http://nabarralde.eus/
Thanks in advance,
It would be very helpful if you could provide a link to your website so we can inspect this problem, and possibly identify the cause for this. I suggest you remove any custom code that you might be using in theme panel, or added to the theme files. Also deactivate all your plugins except the ones provided in the theme package.
I don’t have any custom CSS or any plugin installed.
The webpage it’s located in http://nabarralde.eus/.
Can I write here WordPress background access? Or do I need to write the password in a specific way?
Thanks,
You could try to uninstall the demo, the install it again. It seems some parts of the demo are not working or displaying properly. Maybe something happened during the install process. If this does not fix this issue, you can send us email at contact@tagdiv.com and provide admin login information. You should not post valuable information like login credentials here on the forum.
Also paste a link to this topic so we can identify you.
