I have a question about CTP/Taxonomies for Cloud templates.
“Cali Sight – Custom Taxonomy” in Custom Taxonomies – Templates
” displays the contents of a single post, but “Cali Sight – Custom Taxonomy Global
”, it will no longer be displayed.
Is there a problem with the settings somewhere?
Maybe you didn’t set the custom post type https://i.imgur.com/oKH6f3q.jpeg Please check the settings.
I know that custom posts and taxonomies set in ACF can be used in filters,
But is there a “Flex” that can use field names such as tdcf_price?
Field names for area (tdcf_area) and event date (tdcf_start_time) are registered in ACF.
I would like to be able to filter or sort by these contents.
Thank you for your reply.
I understand.
