custom ad between breadcrumb and title
Hi there and thanks in advance!!
I would like to add one of the custom ads positions for post between the breadcrumb and the title of the post.
How can i do that??
S
First you have to ad the code in your custom ad from Theme Panel: http://screencast.com/t/7BKCFWGNKY2V
After that edit loop-single.php(default template) and add the shortcode <?php echo do_shortcode('[td_ad_box spot_id="custom_ad_1"]'); ?> after breacrumbs: http://screencast.com/t/vqZWJmCSQVm6
Result: http://screencast.com/t/oXbhgMhLbGY
Thanks a lot, i changed it only in loop-single.php do i have to change to all those in red?
seems to be working…..but i am not sure why they are marcked
Thanks again!
I didn’t specify that you can add “custom ad” for template that you use. If you want to use a different template than default(loop-single.php) you can add it in the marked templates that you want to use. Sorry that I didn’t specify this!
