For my domain, pavlikeni.com, I cannot create a custom ad box to ad to my right-most side column. I attempted everything form the admin panel, but nothing happens. There does not seem to be tag(s) for the custom ads to edit and add to the pages. In Widgets you have [tagDiv] Ad box, but no such for Custom Ad 1, 2, 3….. I ended up adding a text box with the HTML code for my custom ads and did it that way, BUT would like to learn how to use the Ads manager from the admin panel. Can you please assist?
Thanks,
Peter
You can use ad box widget in your sidebar, just drag it to your sidebar and set it like this: http://screencast.com/t/UQ5EA3WJy Also you can insert your custom ad in pages with blocks from Visual Composer like here: http://screencast.com/t/BY2DNqIlFl Please make sure that you paste your code in the custom ad box: http://screencast.com/t/6ZgGL78VXbb Notice that the ads system it’s designed to work fine with adsense code, if you use non adsense please check documentation: https://forum.tagdiv.com/ads-system-full-guide/
