If I add custom ad code to theme panel > ads >
<div class="td-all-devices">
</div>
for example to sidebar ad -slot
and then go to front page – TD Composer to edit the page and choose that adslot
it does not work. Nothing is visible in the page source after save
It looks like something was loaded to TD composer on that ad slot into image file (because can see Remove-link) but the image preview is not working.
Please make sure that all steps are made as in our guide from here -> https://forum.tagdiv.com/custom-ad-spots/
Also if there is still a problem, please provide some more details and screenshots, also a link to your website can help.
When re-creating the ads now they worked. Maybe the size definition from auto to same as the external ad was helped..
