Custom ad not showing in sidebar and removing any blocks below.
Thought this looked too easy. I created a custom ad which inserts a simple image. I then used the tagDiv composer to add an element in the sidebar although the image was not showing. I saved and got out of it then not only was the ad not showing but the blocks below where it was inserted are also not showing.
When I go back into the tagDiv editor the custom ad block is there as well as the other blocks. The image url tested fine. Any clues would be great.
Cheers
Check your AdSense code to be correctly added and valid if you want to bring good theme results. Ensure that you are using the latest version of the theme installed via FTP way, clear all the caches and check the results. You can provide your website URL and some useful screenshots with the problem so I can identify it closer.
Hi Catalin,
Updated the theme as you asked and tried other things but still having no luck, even with inline article adds.
I’m not wanting to use ‘adsence’ code but rather custom ads.
The site is ecommunitynews.net.au and you will see in the sidebar the broken images signalling the ad boxes.
Ad has forced the footer into this column.
I tried one a sidebar ad and the other custom using this code;
<div class=”td-all-devices”></div>
I tried it with the inline for articles without joy. I’m guessing it is something simple but it is eluding me.
Cheers
  • This reply was modified 7 years by CameronWeb.
  • This reply was modified 7 years by CameronWeb. Reason: Added a photo
Please send us an email at tcontact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your Ads section. Also, provide this topic so we can quickly identify you.
