Hello
Is there a way to have the Custom Ads (1-5) have the same AFTER PARAGRAPH settings as the Inline Ad zone so that I could put a custom ad within the body of the text?
For example, I set Inline Ad to show after 1 paragraph, I’d like Custom Ad 1 to show after paragraph 3, etc.
Thx!
The theme was designed to add only one article inline ad in post content using the spot from theme panel. To add multiple ads after a specific number of paragraphs, you need additional customization for the ads system. Those customizations involve custom work and unfortunately we cannot offer it for the moment as we work hard on the development, updates, fixes and support. If you need this my advice is to look for a freelancer from sites like: http://studio.envato.com/ if you don’t know how to do it yourself.
Also you can try a plugin with a similar functionality or if this does not help also you can paste the ad’s shortcode into post content: http://screencast.com/t/vi2FEYbCq5wc To get the shortcode add an ad box into a blank page then switch in backend editor copy and paste this code where you want to display it in post: http://screencast.com/t/qBFgo9bxfFG
Thank you for your message!
