Custom Ad Spot Problem
Hi, here’s my problem.
I assign to an Ad Box the custom_ad_1 spot, in which I’ve previously put the Adsense code for a 728×90 banner; but instead I get a 300×250 banner when the page is loaded.
I tried aplying the same code to custom_ad_2 and still get the same issue. If I assign it the header spot, it shows ok.
I’m sorry, this apply to Newspaper 6!
I am not sure I understand your issue or if you still have it.
The ad-sense ads sizes can be controlled from theme panel > ads section: http://screencast.com/t/ExPR3saPBYax For these ads will be applied sizes selected in indicated ares.
For more details about ad-system please check our documentation here: https://forum.tagdiv.com/header-ad/
Thanks! that was the problem indeed; I wasn’t selecting the size from the list; I was letting it in auto.
