Custom ad spots does not work
I have tried to add custom ad spots using the guide here: https://forum.tagdiv.com/custom-ad-spots/.
When I try to add the ad in the widget section only the default sidebar ad works.
Those custom ad spots can be used in sidebars and on pages as well. Place the ad code in the desired custom ad spot, then use it
On pages like this, through an Ad box element
– https://www.screencast.com/t/Jr8tHSomb4
In sidebars as well, like this
– https://www.screencast.com/t/5kypqBiPdC
Make sure the ad code is valid and works. Test it in a different ad spot for example. If the code works it will be displayed by the theme.
Wops, the problem was AdBlock.
