Hi everyone, first I want to say Newspaper 6 is amazing beautiful and conigurable News Wp theme I’ve ever seen,dashboard it’s fantastic, GOOD WORK Team.
But I have a problem, when I change thisand other ad code it’s disappear.
<a href="http://frtya.com/go/btbDW_sGvf/DEFAULT" target="_blank"><img src="http://e1.static.hoptopboy.com/22129/49629/337441/22129A/300x250-xxa_5666.jpg" /></a>
or for header
<a href="http://frtya.com/go/dP_btbDX_sGvf/DEFAULT" target="_blank"><img src="http://e1.static.hoptopboy.com/22129/49629/337433/22129A/728x90-075a_5183.jpg" /></a>
BTW. You have link error in header ad settings http://prntscr.com/81ka8y
Sorry for my language, it’s not my native.
This topic was modified 11 years by
bArA.
Do you refer that the code disappear from panel ad spots? Or your ad is not displayed using ad box in a page?
If you ad doesn’t appear in page, please add this code here – http://screencast.com/t/1ubq37tleuj0 and re-add ad box on the page.
'-- Select an ad spot --' => '',
This issue will be fixed in the next update and we know about the links issue from panel, it will be fixed as soon as possible.
My ad is not displayed using ad box in a page when I add link like this:
Hi bArA,
I have checked again your code and it works fine:
-header – http://screencast.com/t/7uvdbnfC
For sidebar issue please add this code here – http://screencast.com/t/ZQJyFIm04Uv and re-add ad box on the page. It is an issue there and it will be fixed if you add this code:
Then re-add the ad-box block to your page set sidebar ad and re-save the page – http://screencast.com/t/nuGUcSvqk – http://screencast.com/t/mrbTWBP9
@bArA If you still have this issue, please send an email at contact@tagdiv.com and provide wp-access so we can take a look, also paste a link to this topic so we can know who you are and what your issue is.
