I am wondering if I am able to create custom blocks without them being wiped out during the next theme update.
I have created a custom block or two but noticed they must be registered in the td_config.php file. As you know, this file is unable to replaced within my child theme. Is there another way to create a custom block or module? Am I overlooking something? Thanks!
Unfortunately the config file cannot be overwritten via child theme, so you’ll have to edit the main theme file.
But you can check the documentation on how to make a new module-block – https://forum.tagdiv.com/td_api_blockadd/
If you don’t have programming experience I suggest that you look for a professional developer to help you with this, you can find one on places like http://studio.envato.com/
