Custom Code boxes seemingly saved things after removal – help please
Where does the custom code / does the custom code save to?
I saved some javascript code earlier in the box, and now have removed it, yet it still seems to be ‘enabled’ or be doing something with the files, and i’d like to remove the code, it is not in the ‘custom code’ box any longer.
Can you please assist me with this?
Hello ralsiralsi,
All the custom code have to be inserted in that field -> http://screencast.com/t/HaUsPsSMB1 Most likely, this type of issue come from your caching plugin. Try to clear all of caches, purge CDN files and check again the results.
Hey Catalin, i did that, but does the code save somewhere else in the files that may be accessed in the FTP? Only reason i ask is because i have cleared the cache after removing the script, and it still seems to be having an effect on things?
Hello ralsiralsi,
Do you are using the Child Theme? If yes, please try to switch the theme to the main theme, clear again your caches and check it again the results.
Hi Catalin, can you guide me on how i would know if i am using a child theme from the installation, how would i go about doing that starting new installation of the theme?
Thank you
Hello ralsiralsi,
Please notice that the Child Theme is an optional one which comes bundled with the main theme. A child theme is a theme that inherits the functionality and styling of another theme, called the parent theme. Child themes are the recommended way of modifying an existing theme. The child theme should have to be installed by yourself and loaded from the Theme packet in order to use it. For more information about child theme support, please check the documentation here -> https://forum.tagdiv.com/the-child-theme-support-tutorial/ So, if you want to load the Child Theme on your website, please notice that you have to follow the next steps, like this -> http://screencast.com/t/OSutagcxZ -> http://screencast.com/t/uzxsVzwt
