Hey,
Default Blue Problem
Once in a while my site (http://www.dailycat.de) starts with the default blue and turns purple later. I guess this has to do something with the loading of additional css files. Isn’t it possible to fully overwrite the default color in the main css stylesheet that this doesn’t happen?
Feature Request / Ides:
Also I got quite some additional css styling now. Isn’t it possible to integrate the custom css automatically into the css files instead of adding it to every page? I know them modernize (http://themes.goodlayers.com/modernize/) is doing this in a pretty smart way. On every css change they generate a combined css and write it to disc with a version string in the file name.
btw thx for your awesome support team tagdiv!
Try edit your style.css file and using the replace feature replace this color #4db2ec (blue) with your own, like this: http://screencast.com/t/LlpjBGwZ9O
Also thanks for the suggestion, we will thinks about this.
Hope this works!
Hey Guys,
I am also facing the same problem after installing speed booster plugin. I am getting black colour in loading up instead of my set colour. I want to make it white please guide me to resolve this problem.
The speedbooster plugin will move the css to be loaded last so this means all your styling will be loaded last. if you want to bypass this behavior, please make your css changes directly in style.css. Speedbooster and css styles are for advanced users so if you do not have the proper css skills to do it, we suggest hiring a freelancer to help out.
