Documentation here: https://forum.tagdiv.com/custom-fields-support/
Check this topic too: https://forum.tagdiv.com/topic/cpt-custom-field-at-tagdiver-composer-does-not-show-the-acf-field-ive-created/
I already found this tutorial đ
However, it is the case that I do not get the shortcode displayed đ
If you try on the homepage, then it won’t work, only in the next update.
Try to use the element called âColumn textâ or âText with titleâ. âColumn textâ and âtext with titleâ elements have a button called âedit contentâ and if you click on that button, the WP Editor will open and you can add some text/code/shortcode there.
When will the update be released that will allow for more use of the CPT / ACF Fields?
Also –
Will it be possible to show business listings as a page with all of them and be sortable by categories?
And then have layouts, if needed, for more info for those businesses?
The update will be this month and you can find the changelog here https://tagdiv.com/newspaper/?utm_source=forum&utm_medium=menu&utm_campaign=forum_loggedin&utm_content=92178
