Hallo Everybody,
I need to display custom field to my posts.
I have tried to do this with the “Templatic Bagde Plugin” and it works fine when you are in the post but everywhere else on the website (slider, blocks etc.) all the html tag goes away and it remains only text.
For example i have added to a post called “Todays News” the text “-20% Discount” on my homepage when you see this post you see the Title “Todays NEWS -20% Discount” the formating of the badge is gone when i look to the code i see that the span tag is gone. When you click on the post Its working fine.
My need is to display a badge with a discount precentage to specific posts and this badge need to be on this post everywhere on the page like his Title for example.
My Question is How can i do this with your template? Or Can you suggest a plugin that does this?
Thank you Very much for your time
Hello vachos,
Unfortunately, this plugin is not tested with our theme and we cannot say for sure if it will work or not as properly with our theme, sorry! Also, please keep in mind that we do not have any tested plugins in this regard, sorry! If you want to display a new custom field for your website, please notice that you should use the get_post_meta() function and edit the corresponding file with your post template, if you there you display your custom post field. For example, if you have already created your own custom post field and if you want to display it for post template style 1, you should edit the loop-single-1.php core file and place there that function, like this -> http://screencast.com/t/YwV36nTbEgl Please notice that is not a simple task doing this and if you are not very experimented person in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
