Hey!
Them is great! functionality is amazing!
I uploaded custom fonts but it doesnt work… something is blocking them.
I cleaned the cache and did everything right. font files are in .woff format using fontsquirel tool
If you use a cloud template and the fonts are not applied, please edit the page with TagDiv Composer and check if that element has set up its own font and not a default one.
If the problem is still there, please provide more information about your issue, screenshots with the settings you applied and your website link in order to help you efficiently.
A solution for sending a screenshot is this:
