Hey.
Unfortunatly on this website the custom fonts aren’t displayed correctly, for example at the “Blocks/Widgets Title” at the “Article Title” or in the Modules.
Hello !
Please provide more information about your issue, maybe a screenshot. Everything seems to be working on our side: https://www.screencast.com/t/niTMEdGV
Hey
Well there are custom fonts uploaded
And they are implemented on the website in different places.
For example the Font “FUTURALI” should look like “Futura Book Italic font” from here (https://www.wfonts.com/font/futura)
But they aren’t displayed as you can see here:
It worked untill about two weeks ago.
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Did you made some updates to some plugins/theme/WordPress ?
Please try to set those fonts in Theme panel>Custom code>Custom css and set the font name and path from here https://www.screencast.com/t/xtRbZt7kc here -> https://www.screencast.com/t/aJc8xVGip0 also please make sure that you load the font from here, is should look like this -> https://www.screencast.com/t/qj0SWdL4
results -> https://www.screencast.com/t/nBonobIS
Hey. Everything was done as you said.
Deactivating plugins and clearing cache didn’t work. The wordpress and plugins are up to date.
About the other step you proposed:
Now it looks like this https://framapic.org/nOmK8GYAbLuW/9GNPXPd4Kyux.png
And I tried this https://framapic.org/kZzvVFRUC0MB/Klne1D4Ja07l.png
and this https://framapic.org/X14UuFd62hGt/kjlrexVMpfWU.png
Unfortunatly it didn’t work with any of the
The font is load, but is not working because the http, this is wrong -> https://www.screencast.com/t/JVgWoGztytZ it need to be https -> https://www.screencast.com/t/Tuw7yoyZ7 -> https://www.screencast.com/t/hh8NT1x6tCu -> https://www.screencast.com/t/FoNAqWor
