Custom Fonts not loading at all
Hi, I tried loading custom “Hindi” language fonts after converting them using fontsquirrel. Even though the font name appears in the list, the website doesn’t actually load them. Tested this on almost all typography options.
Any suggestions?
Please make sure that you have uploaded your font on the server and you use the exact path at Custom fonts spot – https://forum.tagdiv.com/using-custom-fonts/
Try to create a folder like Fonts in public_html on your server, make sure you have permissions for that folder, then verify in page source if the font is loaded. Also if you want to use it from backend, you can add a custom font, just paste the url where you uploaded the font and specify a name – http://screencast.com/t/bosHz93pa1li – http://screencast.com/t/rDbnlGghhXYt
