Hi tagDiv team,
I have what seems like a simple issue. I added custom fonts in the Theme Panel (shown here), and the fonts are loading fine when I go to http://www.poptawker.com but not when I go to poptawker.com.
It seems like if I modified the path of the custom font files, it would work for both URLs, but that does not seem to be the case.
Any suggestions?
Hello sgtagdiv,
This issue is known when using CDN or loading fonts from a different source. Please try to use this solution and take a look at this: http://screencast.com/t/AMjW530CSH6 and this: http://screencast.com/t/dLjEUGGwQUZ
The solution to this issue is simple. You will need to add some code to your .htaccess file like this post suggests: https://forum.tagdiv.com/topic/strange-chinese-symbols-replaced-icons-and-arrows/
Thank you for the message!
