Sorry in advance for the noob question but I’m very new to this theme.
I want to import a custom header to my website http://www.nswcountryandpicnicracing.com.au and despite my research, I am hitting dead ends, when I feel it should be a pretty easy fix.
What is the easiest way?
Thanks in advance
Hello !
In order to import a header you will have to go into the Cloud Library as you can see here: https://forum.tagdiv.com/header-manager/
Or you can import it from the website manager. That can be done by opening tagDiv Composer on any page and selecting your header to import: https://www.screencast.com/t/kggFDIQljxXH
I hope this was helpful !
