Custom header problem
Hi, I am trying to use a custom header with a main menu and a main menu sticky that is less high, but the sticky menu shows at the same height as the main menu from the top of the page. There seems to be an error as the main menu is visible behind the sticky menu. I am using a widget area in the headers to try to use google custom search but have deleted these and it still has the same error. Any idea how I can fix this?
Website is http://solidarity.asn.au/
Please let me know how you set the sticky. Please don’t use the sticky row and sticky header => https://i.imgur.com/vxG0qlc.png
Thanks that has fixed one problem, they were both selected. Is there also a way to reduce the height of the sticky header so there is less space underneath the elements?
Don’t worry worked it out, I’ve just put negative padding underneath the widget/custom html area which pushes the height out for some reason.
I’m glad you solve the problem.
Have a nice day!
