That banners i think not will fit there, you need to use smaller banner there, please put there the banner you want to use and then give me your site to inspect it for alignment, i can’t align it from a screenshot.
To add more custom ad spot is a little compicated, but you can try, all data is in this 2 files, one handler the panel and one is the widget.
hi,
single post page is ussing td_module_1.php
http://screencast.com/t/sarLgCIa
Thanks for you message.
Radu A.
Hello Marius,
Here’s the link http://temp.nsisongeffiong.com, i’ve tried everything but can’t get the header ads to align.
Also i want to reduce the size of the thumbnails on the Mega Menu
And i would love to have smaller scrollable thumbnails in my similar articles, just like its done in the Mega Menu
