Custom Posts and Adding/Updating Single Post Templates
If I use Toolset for creating Custom Posts, would I be able to use your post templates?
Would I have to create new designs myself? If yes, what exactly would I need to do for new designs for custom posts?
Please advise.
Regards,
Alim
Hello !
If your plugin only affects the post content that shouldn’t be a problem. We have not tested this, you will have to try and see how it works. What I can say is that tagDiv Composer will not work on other templates ( not created with tagDiv Composer )
