Customization help
I am trying to make my site look like this: https://www.thisiswhyimbroke.com/. What demo and settings should I use to make it look like this as closest as possible. I started with ‘Scandal’ which i thought would look good in this model.
Any help will be highly appreciated.
Thanks,
Vivek
Hello vivec80,
Thank you for your interests in our theme! Unfortunately, our theme does not have any such a created demo which replicate 100% the layout of your example website, sorry! I have checked it and I saw that this website has a different menu bar than our theme and many other items that are different from our theme and that cannot be obtained using only the basic settings of the theme, sorry! For example, you should try using the Block 4 with Infinite Load as pagination which can be setup from here -> http://screencast.com/t/uW6EDo2P Also, for more information about Block Settings, please consult our documentation here -> https://forum.tagdiv.com/block-settings-guide/
Please keep in mind that if you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide additional customizations at the moment, sorry!
Hi Catalin,
Thanks for your response. Appreciate the same.
I understand that it cannot be 100% customized. If there is just one thing that i can ask how to change, it would be to display the ‘price’ and ‘Check it out’ thing on the article snippet in article listing like this: http://prnt.sc/dta8vr.
Can you please guide me on how to get the same. Any article to do that would go as well.
Thanks,
Vivek
Hello vivec80,
If you want to use the site for shopping niche you should use the Woo commerce and then you can try to adjust these buttons as you want. For example, the woo commerce page looks like -> http://demo.tagdiv.com/newsmag/shop/ Notice that is not a simple task and any customization work involves customized and we can not offer such services.
