Customize block meta for CPT
Hi, I’m looking for how you change what’s displayed on block7 for a custom post type. Currently, the “post date” is what’s being displayed as the date, and I want to display the “event” date for the EventCalendar tribe_events CPT in the block. Can you point me to how to do this in Newspaper? I assume i need to modify some PHP in my child theme? Thanks in advance!
Unfortunately, this task involves doing such customization and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hi Catalin,
I am generally aware, meaning, I written all kinds of custom hooks etc, I’m just not sure if there is anything special I need to know to do it with tagDiv and newspaper. All I need is a write-up – sounds like you don’t have any documentation on it – or an example. Let me know, either way, I’m just trying to short-cut my work and learning curve on your theme. Thanks.
nm..i poked around and did it by a child theme mod. was just curious if you all had a cleaner way…like with you API or something. Thanks
