Customize Posts and more questions
Hi there,
I browsed your showcases a little and found a few interesting things for my website.
How can I implement such a title-list? (right side) with points and newest posts.
List
How can I get such a post as a post on the homepage across the entire content width?
Post-Style
I discovered the opt-in builder for myself. For example, can you use it to release the content only for subscribers after the first paragraph? Or automatically add a lock for non-subscribers to posts after 14 days?
How can I display the most read posts in a certain category? (Somehow that doesn’t really work even with “most read”, at least Google shows other most read posts than the list on the website)
Thomas
  • This topic was modified 5 years by chip303. Reason: Images not shown
Hello Thomas!
Yes, you can if you will use a cloud post template. The options there could be to split a row into 2 columns, add a flex block with limit 1 in the left column and for the right column:
1. If you need a list, then you can add it with the element “Text with title” for example, but you need to add them manually.
2. If you need a list with the posts automatically updated, then you can achieve this with a flex block, but without the points into the list.
Please check this video, so you can see how I achieve the query from the second image: https://www.screencast.com/t/T86qAuQV5
Opt-in builder is a new feature. In the next updates, we will try to implement also these functionalities.
You can use a flex block with a filter ( choose the category you want ) and a sort order : Popular (all time).
Hello Bettina,
Thank You
How do I get the result of the second graphic?
I managed the first one, and so did the list.
Thomas
Hello Thomas!
Please check the video provided above step by step, so yo can achieve and customize the flex block as in your screenshot. You can filter by post IDs if you need a specific post to appear: https://www.screencast.com/t/LssLUafW
Please give it a try and let me know the results!
