Hello avalera,
The relationship between Blocks and modules can be seen in Theme panel->Blocks/Modules section like this -> http://screencast.com/t/5374u07ep -> http://screencast.com/t/a9T5FwXdn -> http://screencast.com/t/304wvP2ViUH The idea is that the Blocks uses some modules in their structure. Also, please notice that if you want to change the thumbnail for Block 7 you will have to do some changes through the code in order to achieve best results. As a hint, you will have to alter the code from the td_config.php, like this -> http://screencast.com/t/fVUHpHHaPcFC
Please notice that is not a simple task and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
I already made the changes in the config file and now in the settings the Module 6 and block 7 appear with the correct thumb size http://prnt.sc/clflau but in the page the thumbs are still the same site. I already re-generated all the thumbs but I guess I need to change the module 6 code so it will is the 218 x 150 instead of the 100 x 70. Is this correct?
