Hi guys,
My dashboard admin panel will load for all other pages while I am working on those pages but it wont load for my homepage – The header of my homepage will load but not the rest of it including the admin panel across the top of the viewport.
I have loaded this page incognito too and the same thing happens if that is of any use to someone.
Shane
So the homepage does not load when you want tot edit it with the composer. Do you use the tagDiv composer? Is the page built entirely with the composer as it should? Have you entered code in raw HTML widgets in the page, or in text elements (maybe shortcodes)?
If there is no problem with other pages, then there is something specific to the homepage. Default elements provided by teh composer and added in pages will not cause problems, in most cases there were different codes entered in the page by some form, even ad codes. Let us know.
