I used an standard template called “liberty case”. When you look a post for example:
When you fo down the page an emerging sibe bar appears at the wight with 3 news. I do not want this to appear. What i have to do?
In case you are referring to this one – https://i.imgur.com/nbaHu2z.png the go to the theme panel > post settings > related articles and disable that option – https://i.imgur.com/IBDYWEU.png
Sorry, it was my mistake, that one is the “More Article Box” not the “Related articles” https://i.imgur.com/7GxddUU.png
Sorry!
