Hi there.. I downloaded a homepage template and was working with it for the past 7 days.. It was fine.. The default font style was NOT ITALIC.. But today all of a sudden the Default Font Style seems to have changed to Italic.. I didn’t make any change anywhere and actually as far as I have seen, there is no way to change default font style everywhere at once.. But when I add a text box or try to create something, the header, body, all texts are showing Default Font Style – Italic..
Could you pls advise how to get past this..?? I don’t want to keep changing the Font Style to Normal (Not Italic) each time..
This situation can appear if in the theme panel in under the them fonts > general there is set the style italic – https://i.imgur.com/vYN0Xk2.png then the results will be – https://i.imgur.com/XbjRFvM.png
