I have purchased newspaper 11 theme for my site but default Header and footer are not presented in my theme panel whereas i donot prefer cloud library templated because i want to keep header and footer simple but only these two are not working. Since i have also followed documentation for Header and footer styles but these two options are not presented. However, i follow the following steps for default Header styles but it is not working. so what should be done next. Help me out.
How To Setup The default headers:
Step 1 – Navigate to Newspaper > Theme panel > Header style to access the header options. You will see 7 sections.
Step 2 – Expand the Header Style section and select the “no template” option and then choose the desired Header style.
Step 3 – Click the Save Setting button
This topic was modified 5 years by
Shoukat Faiz. Reason: Forgot to tell the steps of default Header style
I update to the latest Newspaper version. Now my header and footer section does not display properly, I get code instead. In the header section I get this:
[tdb_header_logo image=”” image_retina=”” align_vert=”content-vert-center” align_horiz=”content-horiz-center” image_width=”eyJwb3J0cmFpdCI6IjIyMCJ9″]
dyrectory.com business directory
[tdb_header_menu main_sub_tdicon=”td-icon-down” sub_tdicon=”td-icon-right-arrow” mm_align_horiz=”content-horiz-center” modules_on_row_regular=”20%” modules_on_row_cats=”25%” image_size=”td_324x400″ modules_category=”image” show_excerpt=”none” show_com=”none” show_date=”” show_author=”none” mm_sub_align_horiz=”content-horiz-right” mm_elem_align_horiz=”content-horiz-right” inline=”yes” menu_id=”28″ mm_align_screen=”yes” f_elem_font_family=”” f_elem_font_size=”eyJwb3J0cmFpdCI6IjExIn0=” mm_width=”1300″ mm_subcats_bg=”#ffffff” mm_elem_border_a=”0 1px 0 0″ mm_elem_padd=”eyJhbGwiOiIycHggMjJweCIsInBvcnRyYWl0IjoiMCAxNHB4In0=” mm_sub_padd=”eyJhbGwiOiIxNnB4IDAiLCJwb3J0cmFpdCI6IjE0cHggMCJ9″ f_title_font_size=”eyJhbGwiOiIxNSIsImxhbmRzY2FwZSI6IjE0IiwicG9ydHJhaXQiOiIxMyJ9″ f_title_font_line_height=”1.2″ art_title=”3px 0″ f_mm_sub_font_size=”eyJhbGwiOiIxMyIsInBvcnRyYWl0IjoiMTEifQ==” mm_child_cats=”10″ mm_elem_border=”0 1px 0 0″ mm_height=”eyJhbGwiOiIzNDUiLCJsYW5kc2NhcGUiOiIzMDAiLCJwb3J0cmFpdCI6IjI0MCJ9″ mm_sub_width=”eyJsYW5kc2NhcGUiOiIxNjAiLCJwb3J0cmFpdCI6IjE0MCJ9″ mm_padd=”eyJwb3J0cmFpdCI6IjE0In0=” modules_gap=”eyJwb3J0cmFpdCI6IjE0In0=” elem_padd=”eyJwb3J0cmFpdCI6IjAgMTJweCJ9″ f_elem_font_line_height=”eyJwb3J0cmFpdCI6IjQ4cHgifQ==” video_icon=”eyJwb3J0cmFpdCI6IjI0In0=” all_modules_space=”26″ tds_menu_sub_active=”tds_menu_sub_active1″ tds_menu_sub_active2-line_color=”” tds_menu_active=”tds_menu_active1″][tdb_header_search inline=”yes” toggle_txt_pos=”after” form_align=”content-horiz-right” results_msg_align=”content-horiz-center” image_floated=”float_left” image_width=”30″ image_size=”td_324x400″ show_cat=”none” show_btn=”none” show_date=”” show_review=”” show_com=”none” show_excerpt=”none” show_author=”none” art_title=”0 0 2px 0″ all_modules_space=”20″ tdicon=”td-icon-magnifier-big-rounded” icon_size=”eyJhbGwiOiIyMCIsInBvcnRyYWl0IjoiMTgifQ==” tdc_css=”eyJhbGwiOnsiZGlzcGxheSI6IiJ9LCJwb3J0cmFpdCI6eyJtYXJnaW4tdG9wIjoiMSIsImRpc3BsYXkiOiIifSwicG9ydHJhaXRfbWF4X3dpZHRoIjoxMDE4LCJwb3J0cmFpdF9taW5fd2lkdGgiOjc2OH0=” modules_on_row=”eyJhbGwiOiI1MCUiLCJwb3J0cmFpdCI6IjUwJSIsImxhbmRzY2FwZSI6IjUwJSJ9″ meta_info_horiz=”content-horiz-left” form_width=”600″ input_border=”0 0 1px 0″ modules_divider=”” form_padding=”eyJwb3J0cmFpdCI6IjIwcHggMjBweCAyMHB4IiwiYWxsIjoiMzBweCJ9″ arrow_color=”#ffffff” btn_bg_h=”rgba(0,0,0,0)” btn_tdicon=”td-icon-menu-right” btn_icon_pos=”after” btn_icon_size=”7″ btn_icon_space=”8″ f_title_font_family=”” f_cat_font_family=”” f_cat_font_transform=”uppercase” f_title_font_weight=”” f_title_font_transform=”” f_title_font_size=”13″ title_txt_hover=”#4db2ec” results_limit=”6″ float_block=”yes” icon_color=”#000000″ results_border=”0 0 1px 0″ f_title_font_line_height=”1.4″ btn_color=”#000000″ btn_color_h=”#4db2ec” all_underline_color=”” results_msg_color_h=”#4db2ec” image_height=”100″ meta_padding=”3px 0 0 16px” modules_gap=”20″ mc1_tl=”12″ show_form=”yes” f_meta_font_weight=”” h_effect=”” results_msg_padding=”10px 0″ f_results_msg_font_style=”normal” video_icon=”24″ modules_divider_color=”” modules_border_color=”” btn_padding=”0″ form_border=”0″ form_shadow_shadow_offset_vertical=”3″ results_padding=”0 30px 30px” btn_bg=”rgba(0,0,0,0)” icon_padding=”eyJhbGwiOjIuNCwicG9ydHJhaXQiOiIyLjYifQ==”]
