default Post style (site wide) and Default Post style in post doesn’t work in the new newspaper version 9.7.3.
If I change Style It remain always style 1. Please fix soon as possible.
Please deactivate the WPBakery and child theme ( if you are using child theme ), clear all cache and try again.
Also please notice that the default post template can not be edit using tagDiv Compose, only the templates from tagDiv Cloud library can be edit/build using the tagDiv Composer.
Same problem here.
Calin, i already did everything you recommended but istill present the same problem.
Hi @dimartinoa25,
Please provide some more details about the problem you have; if you are referring to post templates, if you try to change theme and you have child theme activate this will not work, you’ll need to deactivate child theme, clear all cache and try again.
