Featured images are usually cropped to the center (X) and top (Y).
How can I have, in the default post template 7, the featured image, aligned to the center center, or center bottom?
Is it possible to decide within the post, or does it have to be a general rule?
I know we can use the API, but my programming skills don’t go that far.
Can you help?
Yours sincerely,
If you use a default template style 7, then there are no more settings for this, that’s why we recommend cloud/PRO template, so you can edit them with the TagDiv Composer.
Or you can check other styles which one suits your needs.
The featured image should have a size of at least 1200 by 675 pixels.
