Default Post Template Per Category and Custom Post Type
Is it possible to set a default post template per category or custom post type? I have several categories and custom post types, most of which will require a different post template due to the nature of the content
Thanks,
JJ
Unfortunately the theme doesn’t have an option for this and you will need custom modifications. You can try this solution – https://forum.tagdiv.com/topic/different-post-template-for-one-category/#post-65047 I have adjusted it for version 6 of the theme.
This suggestion is already added on our list, but I will will consider it for future updates.
Excellent – that workaround will be fine for now
