Default site post template (site wide) don't work correctly
I bought the template Newspaper, and I get along very well with this template.
I’m using Newspaper 6 Child theme Version: 6.0c but I’ve this problem:
I’ve set the default post template with style 1
https://forum.tagdiv.com/wp-content/uploads/2015/05/post01.jpg
I’ve set it from the theme panel: Newspaper >Theme Panel > Post Settings > Default site post template (site wide)
I can not understand why at a certain point (maybe some update?) the default style is no longer applied to the posts and the generated html code is indeed different even though the settings are identical
Here is an old article where the setting are working:
http://www.lumiaitalia.it/lumia-550-sul-mercato-a-dicembre-2015/
Here is a recent article where the setting it’s not applied correctly
http://www.lumiaitalia.it/lumia-550-disponibile-in-italia/
I created an admin account for you so plese tell me how can I send it to you
Thank you
The sitewide post template works only for posts that have the ‘from panel’ template specified to them. If you create a post and select any other template than from panel: http://screencast.com/t/xml6FccBjZSh then it will be over-ride the setting.
Please check your posts to see if the template is set to from panel and let us know.
Yes I confirm this for the 2 posts I sent you
the template is set to “from panel”
In addition, if I override the setting from the panel of the post, nothing changes, the template miss the “float” of the paragraph or something similar, so the image appeare stand alone and the paragraph start in the bottom of the image
I found a solution by myself by removing the tags that are placed from visual composer automatically, when I save the post. Thank
Using visual composer on posts is not a tested feature and we do not encourage it. Good thing you figured the problem out.
