The default theme cannot be edited. The example element title name is not being changed
tagDiv Composer notthing work without any error,
Element title name is not being edited
The title name can be changed but after saving, if the page is loaded, the previous page will be moved. I hope we will get a solution.
With TagDiv Composer plugin you can modify a cloud/PRO template and not a default one.
If your changes is not saving at all, then probably there is a plugin conflict. Please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
Let us know about your results!
