Define author using wordpress standard tags
I am using USP forms to have non-registered users upload images. In that upload process, they input a display name which is kept in a custom field. The plugin will override the theme and show the display name if the theme uses the standard template tags which are:
the_author()
get_the_author()
the_author_meta(‘display_name’)
get_the_author_meta(‘display_name’)
From what I can see Newspaper uses get_author which does not match
what file does newspaper define $td_mod_single->get_author? There is a file Is this something that can be changed in one place?
Each post template uses the get author in it’s corresponding loop file. These are the files responsible with the post templates in the theme
https://www.screencast.com/t/CnEcQIGu
